Boneheaded Question...
Hi, I need to replace the bulb in the front courtesy light for my IS200. I can't see anyway to remove the plastic light cover to get at the bulb.
Boneheaded question: do I have to pull the whole unit down, or have I simply missed something?
And yes, you really can gauge my mechanical expertise from this question...
Thanks Nik - the threads I could find all referred to the dome light as opposed to the map light, but it's more than likely the same process, lever it out with a screwdriver...
Cheers for the help mate
