Torque Settings On Front Discs
clossie
Having read some of the fabulous guides to replacing front discs and pads on is200's on this forum, i thought i would give it a go this weekend as under heavy braking my steering wheel wobbles and there is also a deep enough lip on the front discs to enable me to use them as a soup bowl once removed.
So.
This morning I ordered a set of mintex discs and pads off fleabay for 90 quid delivered and thought I will try to swap them out myself this weekend using your guides.
Before i start however i need to understand the torque settings for the 2 bolts on the callipers and also the 2 bolts on the calliper carriers.
Any ideas?
So.
Any ideas?
This should help you out.Go to repair manual,front brake caliper.
OK, so I tried to swap the discs out this weekend. Darn it the calliper carriers felt as if they had been welded in place. Anywho, after spending out on some new axle stands as well as a new breaker bar, + 2 hours in what felt like 90 degree heat, i gave in, waved the white flag and opened a cool beer.
never been defeated before. gutted. car now booked into a local garage next week..Miffed.
