Lower Ball Joint Replacement
avante
Ok, I've got to replace the nearside lower ball joint on my 1995 GS300 Is this a hard job? What other bits do i need to take off to replace the ball joint? And is it a DIY on the drive type job??
It is a DIY job but you will most likely need either a long breaker bar or an pneumatic impact gun to remove the nut and whatever you do, make sure you get a good quality ball-joint splitter. When I did the job I broke three splitters that I'd bought down at my local car parts place!
Good luck!
  • 4 months later...
My passenger side Lower Ball Joint seperated on me lastnight while driving luckily I wasn't going fast. where is the cheapest place to find the lower ball joints and the upper control arms for my 96 GS 300? I found a few but it doesn't really describe what all is included like if it has the bushings or not anyways anykind of advice would be greatly appreciated at this point thanks.
Yikes, glad you are ok after that happening.
eBay is a good place for the lower ball joints. You can get them for £50 for the pair both sides. Top arms, no idea, eBay do them about £70, the top arms include the top ball joint and the two bushes on the inner end. There is a turorial in my signature to changing the top arm.
