Gearbox Oil Quantity
Sonic1
Hello
How much oil does the gearbox hold,i beleive it is GL3 or 4 75-90 i think but cannot find the quantity i need to buy.
Also is it possible to do with a 1 ltr squeeze bottle with the tube on it to refill
Hi yes correct quantity but I did not find the topping up easy 'there is not much room in the transmission tunnel and I don't think you will be able to get the plastic bottle in .2 tips there is not enough room for a socket so you will need to use a 24 m/m ring spanner to remove the level plug and I found using a suction gun easy; I got mine on E bay item 350288216682 well worth £6
don't forget remove the level plug before the drain plug :winky:
