6Cd Changer Not Working.
If it's a CD jammed inside the changer, it is possible to open up the unit and remove the offending article. I did so on mine just last week, and the changer has been working fine since.
i think they will all work but you will find the plugs are different on the back depending on the code so if you buy a different one ( AND PLEASE DONT DO IT JUST ON MY SAY SO !! ) you really need to ask the vendor to cut the plugs off the car the stereo comes out of with enough wire on to allow you to solder/connect your wires onto once you have cut your original plugs off - dont take this as gospel but im pretty sure its correct
