Rs200Z Diff Problem
SD287LF
Just bought and RS200z about a month back,
and when I turn the steering full from stand still,
the rear begins to shudder and shake as if the diff is locked, and is pulling
one wheel along.
It doesn't shudder or shake in a straight line, although at higher speeds of about
90miles/h or 150km/h, I could hear a humming sound from the rear of the car.
I got a friend to open the diff and have a look but everything seemed fine,
it wasn't welded locked as some drifter do, so the LSD oil was replaced, but nothing changed.
Does any one have a working diff for sale or had a similar problem and managed to
solve it.
Hi Stevie / E910
I will take the car to a diff specialist sometime next week and get them to have a look,
and advise on what ratio and type of diff it is, I wouldn't want to give anyone something that has problems either,
it must be some kind of an after market diff though, I dont think the factory would of sent it out the way it is now.
Have a look on your chassis plate for the diff code. This will tell you what it came with from the factory.
You'll have an axle number like A01A, A01B, A02A, A02B etc
'B' denotes LSD
You can email me your chassis number & I can confirm in Microcat what ratio you have. 4:100 is the most common
