Got my Mk2 GS yesterday and was immedietly disapointed with the sound system :blink: ... turns out the sub isn't working!!! :crybaby:
It seems like the speaker is alright, as when I gently push up the cone from the boot, there is no rough/scratchy feeling, and there is zero sound coming from it.
Could someone please tell me where the amp for the sub is located so I can check for loose wire's etc, or can someone maybe tell me what the problem is? :)
Is it all plugged in at the head unit?
erm.... did you just ask yourself for more info on your own problem? :lol:
Nope... just an additional question and a free bump! :winky:
Surely someone know's, this forum used to be a wealth of information?!?!?!?!?! :huh:
Problem solved!
Just finished stripping out the head unit etc and found the cause to the sub not working :D
The previous owner had fitted a Nokia hand's free unit, and after a bit of searching, found that the Nokia harness that takes the speaker output from the amp to the phone cut off unit had the 2 sub wires missing:uh: So just a matter of adding 2 new wires to the offending length of loom and VOILA!!!!!!! :hehe:
