Mr2 Turbo Restoration - From White Back To Yellow!
A chap from TB Developments got in touch with me after seeing some of my work asking if I could retore the paintwork on his Yellow MR2 Turbo. The paint was very badly oxidised. So he turned up and I cracked on:
First job was to test a small area to see if the paint would come back. I chose the spoiler, so you can see the massive difference it would make, and you can also see just how bad the paint was:
Some further pictures of the paint:
Wheels acid cleaned:
Snowfoamed:
After a few trials I settled on 3M Fast cut plus to begin with on a yellow pad some shots of the difference it made:
Strip up the middle of the engine cover done, again you can see how bad the paint was :
Spoiler done:
Then another pass this time with Ultrafina on a blue pad:
Car was then snowfoamed again and dried.
Now to try and make the best of the yellow. I settled on Poorboys White diamond glaze applied by rotary on lowest setting on a black finishing pad, followed by hand application of Chemical Guys Butter Wet Wax:
The end results:
Cheers
Mike
  • 1 month later...
