Stani's Is200
stani1029
just putting up my progress so far and will update as i go
day i bought the car start of september
photos from today
things to come soon are personal plate, HID kits, 50mm lowering springs, tint windows.
need advice on what colour to put calipers, i have the lexus stickers for them in white but the colour im still unsure. im thinking black??
some more pictures from last night now lowered/personal plate and HID's
next weekend i plan to fit 30mm hubcentric wheel spacers, LED rear lights, tidy the calipers up, fit new timing belt kit, oil filter, air filter, fuel filter, new oil, new coolant, spark plugs and all new belts.
stani
soon2blexus here are my mods and prices:
front grill £50
50mm lowering springs £120
wheel respray £50
HID kits £200
rear lights £200 to be fitted
30mm wheel spacers £220 to be fitted
regarding the engine work here are whats been done and whats to be done with prices:
timing belt was done last weekend. genuine belt and tensioner for £90
OLD BELT
got it all done in 4 hours with 2 of those hours removing the crank bolt and pulley! was an experience as ive never done a timing belt.
parts i picked up today and prices
10L OIL
OIL FILTER AND SUMP PLUG WASHER
ENGINE FLUSH
10L COOLANT
BELTS
6 DENSO iridium SPARK PLUGS
BRAKE CLEANER
GEARBOX OIL 2L
GEARBOX OIL TREATMENT
ive to pick up my air filter tomorrow as he forgot to order it. as for service it was great. he threw in 5L coolant, engine flush, brake cleaner and i got an extra 5L oil for £0.01p
the Castrol gear oil and slick 50 gearbox treatment was bought from Halfords but the total cost for all the above is
£156.44
I am getting a new water pump also. Forgot about that. £98 for that too. And i have the centre caps. I plan to do them i just havent had the time. I dont want to spray over the badge so it means i need to remove it clean them all up, respray and refit, if i dont want to refit the badge i have small holes to fill.
Ongoing project so things will get done eventually
ok i fitted all of the above parts today, the only pain in the ***** was doing the gearbox oil! why dont they make a small compartment from inside the car to get to the refill plug! anywho i created this and manually pumped the oil in, it took about 30-45 minutes to do 2 litres and worked well :)
at first drive of the car power steering was very stiff at points and the belt squeeked on each turn so a little tighten and that was it, anyone looking to do this i recommend doing it yourself, i done more than what is included in a typical service and it took me just under 2 hours and cost £156.44.
less of the stealers and DIY!
list of things to do are:
water pump, new radiator, new Battery, new discs and pads, wheel spacers (when i get them), rear lights (when i get a replacement), centre caps, tidy up calipers, and maybe some stretch tyres
i spent another 3 hours on the car today. fitted the spacers that eventually came. the annoying thing is that i bought 30mm spacers and i received 2 15mm spacers! so there will be no pictures of how much they are out until i speak to the company and see if theres a mistake. i also got my centre caps done and the calipers :) so heres some pictures:
SPACER FITTED
CALIPER FINISHED
CENTRE CAPS
THE CAR AND PART OF MY MICRA TURBO
thanks for looking
