Dvd-Based Satnav
Many thanks for the advice.
How do I create a marked point? Perhaps I should go back one step. This is what I am trying to achieve: I have a load of addresses that I want to pre-program into the satnav (family, friends, offices, etc). I want to add each address as if i'll be navigating to it but I then simply want to store it (presumably as a marked point).
Yep when you go to Marked Points and then Register, you'll be faced with the same screen as normal for destinations. So you hit address, and then enter as normal as though you wanted to navigate there.
