Wheel Bearing Ls400 Mk Iv 1998
Welcome to the LOC.
I don't know if there is a kit but the bearing part number is 90903-63011 and you will also need a replacement circlip and oil seal, try Lexus as it can be cheaper than other sources and the quality is guaranteed.
We have a resident Lexus parts manager on here ACLex who may give you a discount and post the required parts to you.
Hi Mike,
Welcome to LOC.
You could try HERE but don't exclude the main dealer, I have found them cheaper on some parts than anyone else???
Good luck with your search.
Mike
Mike
Thanks for your response. I will take a look Regards Mike
Welcome to the LOC.
Thanks for your response. How do I get in touch with ACLex (sorry for being slow. Can you provide a telephone no.? regards Mike
Hello everyone, having had a lot of work done to my car and being quoted £157 approx to supply a wheel bearing from Lexus i looked elswhere and had this supplied by my local factors General Traffic Ltd. part n/o ABK1493 which was a genuine toyota part!! Complete kit as well for only £47.46 inc. Mechanics fee £80.= one quiet Lexus.I must add that I have no connection with the above named company. Try them for H/Brake cables as well!! Hope this helps you all.
Thank you for supplying the information above, as a certain supermarket says "Every little helps" and it's the same when it comes to savings on Lexus parts.
Thanks for your response. Regards Mike PS I will take a look
