Help, Radiator Losing Lots Water
Evening,
My Lex seems (well was) losing radiator coolant from the top up.
Upon further investigation and a small top up a while ago i have discovered the flow pipe from the bottom of the top up chamber was leaking and has now snapped off.
Any ideas where to get a spare, is it a new rad job or can i swap out/repair this one?
Sorry for picture size just so you can see they lug that is off.
James
I would try one of those radiator repair places for a fix. It is possibly a common problem.
no point in that,,,,,its the fan housing that the bottles a part of......its seperate from the rad.
you could try a good plastic welder or a good glue and sealer if that doesnt work try a scrappys..
yes easy to remove mate provided the bolts come out easy soak them with wd40 for a few days.get a plastic welder to weld the bit the pipe goes on to back on to the bottle and leave the pipe were it is as you cant put it anywhere else..
Hey guys,
All sorted, had a few problems removing the shroud from the radiator, mainly the bottom bolts.
I dropped the under tray to get the bottom 3 bolts out. One was rounded from a previous trip rough arse so I made a 3/8 socket on and got it out.
The pipe had clearly been bodged before with plastic glue, so I drilled and tapped the hole 1/8 bsp and fitted a tappered nipple to suit.
From here I plugged off the nipple and tested with water. No leaks so slotted it back into the car.
Simple 1 or 2 hour job, hardest part was unplugging the Fan connection and longest was dropping the undertray
