I've managed to acquire a 2nd hand radio from a breaker, I intended to replace my existing radio as I have a lot of interference building up on reception over the past year or so.
I've seen the "posts" on removal, so I know how to tackle this, what worries me is the code - I've no idea what the "replacement" radio code is, and no way of obtaining the chassis number of the donor vehicle.
Does this mean that my only option is a Lexus dealer to re-set the unit, or have any of you "wizards" out there cracked this in another way?
The radio doesn't have the code set/enabled by default. I would install the headunit and if it asks for a code, worry about it then. If it doesn't, jobs a good un.
(if the headunit displays "SEC" when turned on, it has a code set)
Hi Tigerfish,
Took your advice, and got lucky (for once in my life) - no code present, so unit worked without a problem.
Although it seems a "messy" and complicated process, it was relatively easy to accomplish - thanks again for your response.
Regards
Ian
