Heating Control Bulb Change
darrenp
you need to remove the whole thing. first the heater vents and tray on the top, then the stereo and heater controls need to come out. remove the lower heated seat switch aand trc unit. just pulls out towards you. then there are 2 numberr 10 bolts at the bottom and 2 at the top. but if you dont want to scratch up your car place loads of tape down both sides of the stereo unit. better to look at the walkthrough for removing the stereo
  • 4 weeks later...
