Fly Wheel Play
lexus22
Hey guys, how much movement/play should there be in a duel mass flywheel? I guess there must be a little but is there anyway to do a manual test??
Also, whats the best stuff to clean up the gearbox??
Cheers.
their should be around an inch of clock wise/anti clock wise movment mate...and do you mean clean the inside of the bell housing??if so brake cleaner if you mean outside a good degreaser and power washer but remember and cover up the hole were the prop goes
Many thanks for that Ormi, bought a used flywheel and box today and as you say, there is around 3/4 inch play and i thought it was fecked!
Noticed there is slight play at the end of the gearbox shaft, is that normal?
By the way, where did you get the body kit from for your car?
in and out or right and left?and what you mean slight mm cm inches?
the kit on my car is a standard kit mate that i fitted....tte front bumper(bit cut out for intercooler,trd side skirts and trd rear skirt
Ormi, play is right to left, guess a couple of mm, no in/out play.
Do like your kit mate, where did you get it?
And "yes" lex2oos, our cars do have a dual mass flywheel...great until they fek up.
