Is200 Cigarette Lighter
Hi there guys just a quick one really, the cig lighter on my IS doesn't work i have only had her a month or so haven't really checked it out yet but does anyone know any common faults with them if any.... also where would i find the fuse for it as i have been told there is more than one fuse box......
Any help would be great thanks guys
if you pull the hole cig unit out thers two pkugs on the bottom...one or both may be loose/not connected, but ul need needle nose pliers to get them out. and the cig fuse is on the drivers side in the right of the footwell..pull off lid and i think its the middle column, second from the bottom. DO NOT qoute me on that, fuse layout is on back of lid. B)
There is also a fuse link in the bottom of the socket too. If it is blown, you can undo the small nut on the bottom of the socket (you need to take the while lighter socket unit out to do it) and remove the insulating disc, put the nut back on and tighten up, job done.
Hiya guys, just to let you all know the cigg lighter was ok was just the actual lighter that was faulty chargers and such all work in the socket....
Thanks for advice tho guys
