Is200/is300 Electrics Question
Hi guys, I have recently purchased a fabulous but thirsty Is300 and I was wondering the following:-
Is it easy to remove the headunit? I have Error 1 on it and I bypass this by quickly turning the stereo on and off but it still skips quite a bit
May just clean the laser if I can get the unit out.
Do the drivers side buttons light up? Im sure only my "Auto window" button lights up at night....
i have a picture but cannot copy and paste for some reason?! its item number 320791439780 on eBay anyway!
Head unit is easy to remove.
Step 1: Tray/Sat nav unit- remove plastic strip from the front of the tray- cross head screw driver or 8mm socket takes care of the fixing holding it it. Plull towards you and up. Place to one side.
Step 2: Remove the 2 10mm bolts.
Step 3: Masking tape/duct tape along the sides of the stereo/dash area- the stereo has sharp edges and the surrounding area is soft plastic and WILL scratch.
Step 4: Heated Seats/Traction button- hold this and pull towards you. Disconnect the switches.
Step 5: Remove the 2 10mm bolts.
Step 6: Raise the unit slightly and pull towards you.
Disconnect the plugs at the back and the job is done.
J
Thanks for answers and headunit link!
i will have a look at the headunit tonight hopefully.......i couldnt find a way to remove the bottom panel where the heated switches are but I will find a way I hope.....
I checked the switches in question and only the wing mirror module does not light up.
is this normal?
I have recently started to get err1 on CDs as well thats why last weekend i installed the Grom Audio unit, very nice it now streams music via Bluetooth from phone to stereo unit.
The heated seat is just a tray, so pull towards yourself and it will be out.. but remember if you are doing the audio, tape and re-tape again the dash, the metal hinges weights a tonne and while you moving around the cables to get the unit out, unless you have taped the area well, it will scratch the dash.
