Obd2 Reader For '98 Mkvi That Works
Having spent far more time than I should looking into this, I finally ordered a code reader (cable and software) from eBay. An "ordinary" OBD2 reader won't work as the port isn't fully compliant, this one uses what looks like original Toyota software and will work for a whole load of toyota vehicles.
It also has an OBDII option, which I take it means it will also work as a reader on other compliant vehicles, though I haven't got a newer car to test it on.
I wasn't sure if it was working properly,as I didn't get any codes, but it looks like I'm lucky enough not to have any at the moment.
Rudd brought his car round and we got some codes, with descriptions, and cleared them, so it does the business.
You have to do a scan first which takes 5 minutes, and the Options tag to reprogram little things like wether the key tilts or opens the roof didn't work.
A search for "Mini VCI FOR TOYOTA TIS" on eBay will bring them up. I went for a UK supplier in case it didn't work, but the overseas suppliers are cheaper!
Beware the adds that say "not only provides commonly used J1962 connector, but also provides the old 22pin connector for Toyota." if it isn't actually in the pictures too, as it looks like they all copy each others text and I didn't actually get the extra cable. I pointed this out and the add has since changed. Bit miffed about that.
I got this as I have just sold my Mk1 and got a MkVI- what a difference! I thought I enjoyed driving before :shifty:
Thank you, that is very useful information given in the past there have been members with issues reading the codes even with professional garage readers who have then had to spend £££s at Lexus to get the diagnosis done.
I can vouch for this one. Worked briliantly, even live data etc. Hopefully next week Ian will be so kind to clear my DTC in the hope it won't return :)
