What Could It Be?
hi all
Alright, at first I just thought that my tires needed air, but even since I put air in them this problem has gotten worse.
You know how it feels when you go down a bumpy road? cars tend to follow the road... in a bad way? Like when you come over the crown of the road, it redirects? :nuke: Like the wobble back and fourth with bumps?
im running 225/40/18
3 with 6mm+ tread and one with less then 3mm which is on the front passenger side
wheels are rx450h wheels with et35
things i had changed in the last 6 months are
inner and outter tie rods
upper balljoints
lower balljoints
lower control arm bushes
caster bushes
and Alignment done by wheels in motion
it passed its mot just last week
thanks in advance guys :(
wahid
Try swapping fronts to rear, see if it makes any difference - if it does then that would point to the problem being tyre related.
While they're off, check the tyrewalls for bulges.
I would say it could be tyre related.
I had a v grove eagle f1 with 8mm tread on side at the front and a very worn dunlop about 2mm thread straight grove tyre on the opposite side and the car didn't feel planted. It felt as you described with the steering following the road to a point that it was uncomfortable or felt less stable.
would try that mate
ya mate i have same v grove tread on one side and a dunlop 3mm straight grove tyre on another
will swapping fronts to rear to see if its make any difference will keep you guys updated
thanks for reply guys
wahid
