Ls430 Front Brake Piston - Need Help Quick
Mike Floutier
This car is for work so I need to get these pads on quick.
I've done this a dozen times but not had this problem.
In retracting one of the pistons, the other came out as far as the disc, probably should have been more careful.
Now it doesn't want to go back in. It's not fallen out or anything, just out as far as the disc.
By refitting a worn pad on the other side I can now get a lever 9" between piston and disc BUT it's not budging.
As help would be appreciated.
Mike
As Rotty says loosen the bleed nipple as this takes the pressure off, if you have a G clamp try using that to refit the piston but make sure the piston is square.
If you have a couple of thick nylon cable ties put them around the other piston to stop that moving.
