Front Grill
walker24
Heres mine, ive wrapped the bottom part of the bumper using avery vinyl that i was given as a sample. its fairly easy to do but you just need to take your time. Also get enough incase you make a mistake the first time.
cheers mate thats exactly what i was after. Did you do the carbon wrap on the bottom yourself? if so which did you use and was it relativley easy to do without getting bubbles?
best is soak it with lite soap water (washing liquid) smooth it all out. it will stay on after dry out
Hi would you be able to post more more photos of your bumper from different angles thanks i think it looks great I'm wondering wither to do carbon, grey, black or a bronzy colour like the 2004 on headlights.
your opinion would be appreciated too ;)
Personally i feel that wrapping is better for me as if you do decide later down the line that you dont like it you can pull it off and youre back to normal. Ive also just wrapped the "L" badge on the grill and ill get some photos of that up soon. As you can see ive done headlights and fogs black aswell and i think that it all kinda compliments eachother.
An heres the recent one with the "L" badge wrapped aswell
Wrapped mirrors would be nice to.
see where the bottom bar is wrapped on your car I'm considering filing the curves where the bar turns to the vertical or sides of the opening. so that there is a clean edge to wrap and it will look like a separate part rather than a wrapped section if you get my drift?
