Has anyone fitted these to their LS?
I have a set to fit but they need the power taken from the ignition side of the electrics so they come on as soon as you turn on the ignition to operate independantly of the main side and headlights.
Any advice as to where it would be easiest to take power from would be appreciated.
I don't know if the series IV is the same but my lights automatically turn off when the driver's door is opened so I leave my sidelights on all the time, the sidelights are also fitted with LED bulbs so are nice and bright.
If your lights are the same I would connect the DRLs into the sidelight wiring as it is easy to access and close to where you want to fit the lights.
Otherwise you need to find an ignition switched supply preferably within the engine compartment or look for a route from the cabin.
