Windows Won't Open From Driver's Controls
IS 250 SE-L mm
I have just noticed that even though all my windows work, I cannot open any of the other windows from the driver side panel.
They are not locked although I did notice the other night that the green light on the buttons was flashing slowly, but I can't remember if that was only when I activated the window lock.
The window lock seems to work because when you turn it on or off the lights on the switches (on the driver panel) will go on or off accordingly.
