Battery/radio Code
gji25
Chances are you will.
There may be a way of disabling the code whilst changing the Battery or acessing the information from the radio, have a look at your user handbook.
It is also said that the code is normally the last 3 or 4 digits of your VIN but if it has been changed beware.
Another option is to use a backup supply which normally connects to the cigar lighter so power remains on to the radio whilst the Battery is off.
After a search I found the information below, it would seem the radio is not coded.
http://www.lexusownersclub.co.uk/forum/index.php?showtopic=77040
