Fitting Rx400 Rear Led Lights To A Rx300 Straight Forward ?
As it says in the title really
, i have a 2004 RX300 and wondered if anyone has fitted RX400 LED rear lamps to one .
if so is it plug and play or does the wiring differ from the standard bulb setup on the rx300 to the LED bulbs in the rx400?
anyone been down this road with advice would be great thanks :winky:
I am not sure I understand your question. All the RX300/350 I have seen have the same rear light clusters as the RX400h... all of them LED. The only difference I am aware of is at the front, where the fog lamps are of a different shape.
the rx300''s look like led's due to the lens , but are standard bulbs inside , but the rx400h are LED setup rear lights.
