Fog Lamp Question
Hi People
Can anyone tell me if theres any difference in fog lamp units from is200 to is300? I know IS300 is yellow but is it only the bulb or is the actual unit different??
They're both exactly the same mate. Only difference being bulb type on all models from about 2003>
I think the yellow IS300 fog has a plastic filter.
my 300 is 2002, so, if i'm reading right, my bulb will definitely fit in the fog lamp unit of a 200 from the same year?
Yes, if you get 2003> onwards fogs, you will have to cut the cables and manually touch them to the conenctors. It's a simple job... the only difference between the actual lamps is the connectors and the IS300 has a yellow filter on the projector.
PIC of 2003 onwards fogs:
post-37995-0-03101500-1368390990_thumb.j
