My is250's idle RPM seems quite high to me, around 1300-1400 upon starting and in park but when I put it into drive or reverse it drops to around 700-800 RPM. Is this normal? What RPM are you getting?
From cold it will start around 1400rpm then drop to around 1200 then once up to operating temp will drop to around 700rpm.
This seems to be normal.
If anything once warm the idle can drop a bit low around 550-600rpm which causes a slight idle sensation.
Keeping the air con on keeps the idle at a steady 700rpm which gives perfect idle for me.
Carl
Carl
Exactly so.
