No Fans.
Yep, the fan switch is on the bottom drivers side of the radiator. However, have you tried turning the Aircon on? With the aircon in action they should run all the time. If they don't, then chances are it's not your temperature switch on the radiator. They are two speed by the way too. With aircon in action they will run in slow speed all the time, with bursts of high speed when required. If they don't work at all then I'd guess fuse or supply problem of some sort.
