Is200 Headlight Washers Semi Working
hi all,
my head lamp washers are either knackered or need a tinker, when the button is pressed there is noise of a motor working, the passenger washer goes half way up but no spray, the driver side does not rise no spray, also the washer jet on the driver side is missing, b4 I go excavating the front end is there a more simple solution, where do I start!!!???, what Is required to fix this???
cheers all
Richard :doggy: :doggy: :doggy: :megaangry: :megaangry:
