Some Dash Lights Stay On
I did post this before , but more imformation has come to light .
a while ago my lighter was not working so had it rewired. after that I had 3 lights stay on , on the dash when the car is running , the abs light the trc light and the handbrake light . I still cannot find the problem ? but now I have been told that the feed for the lighter was taken from one of the heated seat switches . do you think this could be the problem ???
would be grateful for any advise as really need to get this sorted .
many thanks
warren
If all was well before the job was done it would appear something was messed up when doing it causing the problem you now have.
If it was done by a garage I would be asking them to sort it, not sure where the feed should come from without a wiring diagram but the garage should have checked this to make sure it is correct.
