hi
why does it seem to be beyond the capability of vehicle manufacturers to produce a product that does not leak when it rains!
i have a water ingress behind the front seats where the transmission tunnel would normally be
any thoughts?
les spragg
I would check the sunroof drainage holes first as these can get clogged. There are two of them - try compressed air or give it a prod with strimmer wire. Worst case you may have to pull some interior panels loose and check that the drainage tubes haven't come loose.
I think I read somewhere that someone else diagnosed water leaking in from the windscreen - it was replaced and not bonded in properly.
Hope you get it sorted.
