I have a 2010 Lexus 220D SE.
On some occasions when I press the Start/Stop button to turn the car off, the heater fan keeps running continuously, unless I turn the fan off before turning the car off.
This has caused the Battery to run flat a few times. Previously when I pressed the Stop button, everything shut off normally. But now, on some occasions the heater fan keeps running if not turned off first, but lights and all other electrics turn off as normal.
Could this be caused by a sticking relay? Or could something else be the cause?
