Ball Joint
fitter
Hi all
I had my is up on the kack today (cleaned and regreased the pads and check over) and i noticed some play in the bottom ball joint when i lift wheel up and down but nothing at all pulling the bottom of wheel
its knakered right ?
thanks fitter
Then you will have to replace the attached track rod end. I had exactly the same problem. Seems to be a common problem with these cars - see other posts on various creaking, squeaking and grinding noises associated with suspension issues. Hey ho, nothing's perfect - not even a Lexus!
