Ars Light
DALE69V
Think it's Active Rear Steering, basically on your V300 you've got 4 four wheel steering, if the lights come on there's a problem with that.
If it's goosed it can be expensive to fix, a lot of the guys fit the TOMS ARS Canceler which basically locks it all down I think, maybe even replaces it, and then there's something which plugs into the sensor so that the car thinks it's working even when it's not.
The TOMS ARS Canceler is supposed to increase the performance of the car, and also reduce the weird sensation you can get from the back of the car at speed!
You're not far away from me, not seen any other V300's on the road around here!
Yep Aido is spot on! Just one thing - the ARS kicks in at speeds of under 30mph, and shuts off at anything higher. It's mostly to make your turning circle smaller not to mention it does alter your "alignment" settings after some time.
Best thing to do is to get the ARS Cancellor. You've got PM for a cheap reliable source! :).
Hi Aido
Only had the car for a month now :D
Got a few problems with her to sort out but getting there slowly so hopefully should make it to some shows and meets soon
Cheers for the help
Dale
