My Warranty Chances With This......
Hi all,
I've been reading with interest the thread on the seized calipers on a 40k IS200.
I have a problem with my 44k IS200sport - the clutch release bearing squeaks. On idle with car in neutral and clutch up there is a HORRIBLE screaching sound. As far as I can deduce, it is the clutch release bearing (or thrust bearing).
The car is under a 1yr dealer warranty (3yr manuf warranty ended 1st march this yr) and my opinion is I do not expect to buy a car such as this, only for it to squeak, regardless of whether it's a wearable part or not.
Has anybody had any experiences with this, or any advice? It's a very embarrasing noise - luxurious car, nice image.....SQEUAK SQUEAK SQUEAK
Thanks for any comments,
Tony
Hi Tone,
Dim question No. 14 :withstupid:
Reading you post, the car seems to be outside it's 3yr warranty, but is it still subject to a 1yr warrranty from your dealer?
If so, then you're ok. :hocus-pokus:
Go get it sorted under the 1yr warranty.
I think if the noise stops when you plonk the clutch pedal down,
It could be a gearbox input shaft bearing.
Anyway, should all be warranty work ...
yeah - that's what it does !!!
My concern was that they would say clutch related is a wearable part.
You're correct, 3yr manuf warranty is out but i bought from a dealer only 2 months ago so i have a 1yrs dealer warranty still.
A phone call to Lexus Canterbury it is then
Cheers guys for your input !
