Just put in the pliers and break up the orange reflecter you have to be quite hard with it .The headlight assembly is quite hard to get out but with a bit of persuasion it comes out .On the light assembly there is a holder for the terminal block take the holder off as it makes it a whole lot easier to put the light back in.Be carefull with the opening on the indicater as it is made of soft plastic and distorts easly.
to get of headlight remove indicaters by removing small screw at top then give it a pull should come straight out .then undo all the screws that secure plastic strip on top of headklight .under this you will find bolts take these out and also the other bolts that secure headlight .then you should be able to take out headlight ,it is bit of a struggle but once you get it at the right angle it slips out.don,t forget to disconnect all wires on the back of unit.i take it you are in america so i am persuming that your gs is the same as the model i have :question:
I am thinking the american version is set up slightly different. I had to Take a few screws out from the inner fender to reach 2 nuts that were holding it in from the inside, then on top of the headlight itself i took out 2 bolts and the headlight simply came out. Very easy, the clear corners look wonderful! I really appreciate all of the help you guys have given me, on took 1.5 hours to complete! Thanks so much! :winky:
