Replacing rear light bulbs
Cheers guys. A pair of bosch 955's are ready to go in. Will tackle this over the weekend.
Only one required. Left side is reversing light,right side fog which is a non replaceable LED.
Sent from my SM-G925F using Tapatalk
What!?! There's only 1 reversing light?
yes, one each reversing & fog. So maybe your revering light hasn't blown!!
4 hours ago, matt8 said:
If it fails, what does one do?
The rear fog light is several LED`s intergral to the light cluster. LED`s typically last for 50,000 hours. How many times have you used your rear fog lights?  Running every day for 24 hours all day it would be 6 years of use!!
They will never need replacing same as the rear lights brake lights etc!!
I have not worked out why they still use incandescent bulbs for the revering & indicators though.:whistling1:
Ed:yes:
Thanks, @capese21 for the info.
There will be occasions (how many I don't know) where LED actual lifetime is far lower than expected.
Is it possible to change the whole cluster if a light were to fail? What other LED lights are on that cluster?
Will change those reversing and indicator lights to LED when they eventually fail.
If you were involved in a rear end shunt then Lexus would no doubt sell you one. I doubt they would fail in normal use though. The IS has all LED rear clusters apart from the indicators & reversing lights.
Even if you half the service life an LED it will last the lifetime of a car. In use for 10 hours a day then around 15 years.  Do you drive 10 hours a day every day with your fog lights or any other light on?
I was thinking, perhaps broken due to defective manufacturing that causes substantially shorter life, but still working as it leaves the factory. Eg. 100 hours.
Then again, I don't know how LED's work, perhaps it is not possible to have ones that'd perform as miserably as what I was thinking above.
