Gruntfuggly
Central locking intermittently forgets?
I have an odd problem. Every few days, when I go to unlock the car with the keyfob, it doesn't work - the car doesn't seem to receive the signal. I then have to unlock it with the door lock, which sets the alarm off but relocking and unlocking again usually stops the alarm?
I've tried a new battery in the keyfob, so:
1. Does anybody have an idea why it is losing sync with the keyfob?
2. If the alarm can be disabled by locking/unlocking with the key, why does unlocking it with key set it off in the first place?
Thanks in advance for any suggestions!
I can't offer a solution Nige but spooky you should post this because it's happened to me a couple of times recently. New battery too. A Google of "is300 remote unlock problem" throws up some interesting solutions and proves it's not just us!
Interesting that somebody mentions it could be the car battery - mine has gone flat a few times recently, although when it refuses to unlock the car, it still starts OK. Maybe I should treat myself to a new car battery and see if that helps...
Once the alarm is reset it seems to work fine again, so I don't think it's anything physical.
I'll let you know if I get anywhere with it. At the moment I'm locking the car with the door button - it's too embarrassing when the alarm goes off at work!  :unsure:
Not quiet is it? Sometimes I forget to blip the remote if I unlock the boot with key. Certainly gets the blood pumping.
