Bondis
Conversion of OEM IS220d F Sport Headlamps to OEM IS200d F Sport Headlamps
Hi all!
First and foremost I am new to this forum. I bought a 2010 Lexus IS 220d F Sport from the UK and imported it to my country. I bought the 220d F Sport and not the 200d F Sport for three main reasons:
1) More power
2) Mark Levinson sound system
3) Seats with memory function
However, doing this meant that my car would have no day time running lights as standard. This is something that I still really want.
Does anyone now if it is possible to convert from a 2010 OEM to a 2011 OEM headlamp? Will it be an easy swap? And will the DRL work just as a plug and play or will I have to take it to a centre to get it programmed? From the satellite switches i have no access to DRL function, and this is where i assume it should be to switch them on or off.
I have contacted the Lexus Official Store on eBay and their reply was:
"If the customer is looking to fit a different headlamp from a different spec of vehicle we would not be able to advise regarding if it would fit the vehicle as the wiring may well be different/has not been tested so we cannot sanction changing the original spec. I can also confirm that there are no accessory DRL/s available."
Before I got this message they however have recommended part number 81140-53351.
https://www.ebay.co.uk/itm/Genuine-Lexus-IS250-220D-RH-Headlamp-Unit-Assembly-04-10-08-10-8114053351-/262303658199?hash=item3d128430d7
In my opinion, 8113053250 looks like it has DRL function at the bottom of the headlamp unit, and is also much cheaper.
https://www.ebay.co.uk/itm/Genuine-Lexus-Car-Replacement-Headlamp-Unit-Assembly-RH-8113053250-/251651200663?hash=item3a97949697
Attached find the two car models i am referring to, and see the difference in headlamps. IMO the DRL function looks amazing.
I tried to keep the post the shortest length possible. Any sort of information and help would be very much appreciated.
Peace be with you guys. Have a good day.
Welcome Matthew :smile:
This video shows you how to swap the lights:
https://www.youtube.com/watch?v=YnwjS5aN_QI
Strange that the pre facelift light is so much more expensive.
Oh, and we always encourage people to post pictures of their car, so feel free. :smile:
The one in the video is not OEM I guess, and so the AFS light in the cluster will switch on. Also it does not seem to be Xenon headlamps. But thanks for the information.
Attached is a shot of my car, literally in showroom condition, when I bought it last June. Obviously all stock... so far :)
Nice looking car you got there.  Don't see many in black.
Sorry, I should have mentioned that I posted the video only to show you how to change the light, not the purchase it from them.
I assume if you get OEM lights then you won't have a problem with AFS, although I would think that the satellite function won't work.
Might be worth looking for someone who is breaking a facelift car.
Even if it's an easy enough job to change the actual light units, your car may not be wired for DRL functionality.
My 2005 RX300 has a fusebox in the engine bay and all fuses are labelled up to show which circuits they control. If you pull any fuse out of its holder you can see two metal contacts in the holder and, obviously, the fuse is just a bit of wire that bridges those two contacts, which allows the current to flow.
According to the label in the fusebox, one of the fuses (I think it's No.10 if I remember correctly) is for the DRLs. However, in reality, there is no fuse in the No.10 position and if you look down into where the fuse should be, there are no contacts there to push the fuse into and no wiring exists for a DRL circuit.
Maybe the American, Japanese, and some other markets around the world sold RX300s with DRLs, but the UK market didn't so no wiring was ever installed for them.
Luckily, the RX300 uses an amber bulb through a clear lens for the indicators so I got these switchback LEDs from eBay, along with a couple of relays and they work really well. Not as good looking as the ones you want but an easy, cheap alternative.
@Shahpor, thank you :)
@sorcerer sounds like a good idea. However i will dig deeper and try to find a pair of OEM headlamps from the 200d model. Then I'll manage with an electrician's helps to have the DRLs permanently on. I wouldn't have the option to switch them off, but i see no reason for that. I will also try to find a wiring diagram for the two models and compare the two. Things should be more clear then.
Thank you both for your help.
DRLs should only come on when the engine is actually running, and not when the key is in either the ACC or IGN positions, but I think most aftermarket DRLs are wired to come on with the ignition, as mine are. I only found out a couple of days ago that the way to get them on when the engine is running is to take the power from the alternator - as soon as the alternator starts to charge the DRLs come on.
Quote
I wouldn't have the option to switch them off, but I see no reason for that
They have to go off when the side/position lights are turned on or at the very least they must dim to about half of their normal brightness so that no one gets dazzled by very bright LEDs at night. Have a look at my video in the thread below:
Well, I can't help you with the post facelift cars (assuming there is any difference), but here are what I have on the wiring of the headlights and AFS system on the older cars:
AFS.pdf
HL.pdf
AFS.pdf
HL.pdf
Thank you! very much appreciated!
indeed, this is why i would definitely need an auto electrician's help :)
  • Similar Content
    • By Stevebrooks
      I have followed all the other suggestions on this sight and others regarding disabling the annoying seatbelt warning gong, but no luck. I have a Gs450h and most of the suggestions are for iS and earlier GS models. Does anyone know how to disable the gong for a GS450h 2012 model?
    • By Linas.P
      Just bough myself main beam Osram Xenarc Cool Blue Intense D4S for £41 (standards price ~ £80). Sadly, was limited deal on amazon I believe 2 items left, but the time I bough and none by the time I finished making the post.
      Can anyone advice on High Beam?
      I know there is part thread just above, but it seems nobody has any recommendations for high beam?
    • By Keleko
      Evening,
      I've got a 2012 GS450h F-Sport and I have to pull the boot lid pretty hard to close it, should it have a soft close boot like my 2008 GS450h did?
    • By Linas.P
      I believe we had multiple threads about different options so sorry for starting it all over. However, I wanted to create single one where we have a list of recommended bulbs for each application.
      To begin with making a clear distinction between 2 options. As we all know there are HID/Xenon set-up and Halogen set-up. High beam and parking lights would be the same, but the Main beam cannot be more different.
      2 main criteria are Colour and Light output (strength):
      So the light output is calculated in Lumens (lm) and the higher the better, here is where I guess many people get it confused with colour and latter is not "the higher is the better.
      Colour is represented by kelvins and the "higher is the bluer", quick introduction into Kelvin rating as well:
      Based on the scale above Halogens are in the range between 2500-4500. I believe standard Lexus ones were 4300k giving nice white colour though quite weak (in lm). Anything below 3000k I consider vintage or fog. Not sure about Lexus parking/side lights, but they are same for both types, yellowish ~3000k. High beam is the same for both cars again, I believe it to be similar temp as HID/Xenon ~ 5500K. This is as well around the range I prefer - I don't really like anything above 6000K aka blue light (or aka cheap Xenon/LED kits). As well I have adjustable video light with 3200K to 6500K range. I personally found that ~5300K is perfect for my taste, so I guess anything between 5000-5500k would be ok.
      Xenon/HID Recommendation:
      High beam (standard 5500K/~?lm) - I believe it is HB3 are there any LED options? It seems that best HB3 bulb I can find is ~1700/1800lm which is fairly weak.
      Main beam D2S (standard 5500k/~2400lm) - Osram XENARC COOL BLUE INTENSE (sounds scary blue, but it is actually 5500k), Cool Blue is as well rated at 3200lm whilst "Night Breakers" and "Long Life" are both rated 2800lm and colour is 4350k (kind of towards yellow at least on paper). There are as well Phillips Xenon White vision ~ price range £65-85
      Side light T10 - PHILIPS XTREME VISION 360 LED T10, there are 4000/6000/8000k versions ~£13-17
      Halogen Recommendation:
      (LED/Xenon conversion kits are illegal to use in UK due to "construction and use" and therefore I would like to avoid recommending any of these).
      Main beam - I believe it is H7 , what are the best options?
      I am not sure if I am going to be able to edit an original post due to changes in forum, but I guess I will summarise suggestion in a new post.
    • By Ben1989
      Hi everyone.
      I've searched but can't seem to find any information regarding HID kits on their cars so thought I'd ask.
      Has anybody done a HID upgrade on their car? If so, which kit did you buy?
      With my CT200h I'm looking for a kit that will work with the auto-light feature (H11 bulb). I had a cheep ebay kit on my Honda Accord and it worked faultlessly. Hoping somebody can point me in the right direction of a reasonably priced kit that is tried and tested.
      (please no "HID kits are illegal" etc).
      Many thanks, Ben
