Toyota Crown Majesta 4.6
It is roughly same size as LS460L and with it being a Jap .............. more toys !!!
Also available with the earlier 3UZ-FE 4.3 and 4WD
http://www.tradecarview.com/used_car/japan%20car/toyota/crown+majesta/14912069/
Wheelbase 3,225 mm (127.0 in)
Length 5,165 mm (203.3 in)
Width 1,910 mm (75.2 in)
Height 1,525 mm (60.0 in)
Curb weight 2,130 kg (4,695.8 lb)
2,430 kg (5,357.2 lb)
LS460
Wheelbase 2,969 mm (116.9 in) (SWB)
3,091 mm (121.7 in) (LWB)
Length 5,029–5,060 mm (198.0–199.2 in)
5,151–5,179 mm (202.8–203.9 in)
Width 1,875 mm (73.8 in)
Height 1,466–1,481 mm (57.7–58.3 in)
Curb weight 1,925–1,965 kg (4,244–4,332 lb)
IT'S A TOYOTA TANK !!!
P.S even though the immense size of this barge it uses the IS and GS running gear !!!
I have a real soft spot for it, especially the 4.3 4WD version !!! wonder what its like in the snow
It's longer than the LS400 and mine only just fits in my garage so this wouldn't.
Very nice motor though, love the rear centre console that extends over the transmission tunnel.
Didn't earlier versions have a V12 engine?
Anywhere between £8000 - £25000 depending on mileage and toys
This model is 2009-2012
Some come with valor seats because in Japan the leather will just burn your bum off
Then you have the latest version
The Toyota Crown Athlete 2012 onwards
toyota-crown-athlete-1-e1356599654975-63
Nope
That was the Toyota Century
This was the 1991 model Toyota Crown
Do you recognise it ???
How about the 1999 model ??
I like the Crown Majesta and some even comes with fog lights too ready for UK market
That will be my next car as its the newest car to date with the 3UZ-FE as I prefer it to the 1UR-FSE
And I think it is really nice and a bit different
