You can see the discs through the wheels if you've got standard (or most other) wheels - see if the rears are similar to the front (ie two discs separated by a whole lot of fins) or if there is just one disc (similar to most other cars' rear discs - check on a neighbour's hatchback!)
Then report back!
Cheers for the reply, they do look a bit larger but I will have a proper look tomorrow. Thanks for the replies I will report back with the findings. Toffee what design MTEC's did you go for as that's what I'm looking at, also what pads did you use?
