Changing Spark Plugs On Is200
leea121
There is no standard for heat range.
Denso heat range is 20, NGK is 6. For your mods Zee I would have thought you need to use the next number up for a slightly cooler plug.
Denso part number is SK20R11
14 mm thread - Iridium tipped, 20 heat range, Resistor, 1.1mm gap.
So which one is better, Denso or NGK?
Sorry di not read the rest of the thread before placing comment. I have a Standard IS200 Sport, I guess I will go for the Denso IK20's. Cheers.
just fitted my denso ik20 spark plugs ,had no problems fitting them also changed pollen filter and air filter. the car feels even smoother to drive.
do you guys reset the ecu after fitting the spark plugs?
thanks
