Is300h Engine Oil Warning
Hi all,
The engine oil warning has recently pop up on my screen when i start the car. It says to contact my dealer, which I did
and they'd like me to bring it in, however they are an hour away from me so it's not an easy drop off.
I've done 20k miles and its due for service in December. Has anyone else had this warning and if so did you just top up with
oil or did you bring it to your dealer to have a look?
Somewhere in the vehicle settings menu a reminder can be set for oil changes and loads of other things. I think it's probably that and triggered at the 20k mile mark.
So i checked the maintainence settings and it does look like it had been set at 20k which tripped the warning. Checked the dip stick and the oil level is fine. So booked it in for service. I live
about an hour away from dealer, so they said they would come and pick the car up for me, leave me with a courtesy car and then drop the car off. Lovely!
That's the sort of service we like!
