Is300 Stereo
Just make sure you check that the one you buy has the same number on the front as they's 4-5 different types and they have different connections on the rear!
Removal is easy enough, there's a few videos on youtube showing the process.
You are probably best off getting a fascia plate adaptor and harness and fitting an aftermarket stereo. At the age that they are most of the original Lexus head units have serious issues with the cd changer (error3 code).
Mine lasted ten years then I replaced it with a reconditioned one from a scrap yard, then not long after that ended up just getting an after-market alpine unit with Bluetooth.
