Leak
Hk
Hi peeps newbe here.
my Lexus rx300 04 plate is letting water in somewhere ,the front passenger side footwell gets wet and behind the drivers seat passenger foot well also gets wet. Does any one know if this is a common fault or has anyone had the same problem and rectified it . Many thanks Hk
Hi Helen and welcome to the LOC, we are a friendly bunch and some of us even know how to pull them to bits and put them back together again, with of course the one bolt and washer left over.
I cant help with your present query but I'm sure someone will be along ASAP.
We recommend you spend a couple of mins looking over the rules of the LOC, we will be asking questions later
http://www.lexusownersclub.co.uk/terms-conditions/
Regards Mike.
HI Mike
Welcome to the club. Regarding your leak. Check the drain holes in your sunroof. If they get blocked the water finds its way to the passenger footwell. Get a long piece of curtain rod & poke it through the hole until it comes out underneath the car & it will clear it.
