ATF cooler - help
Am I right in thinking the small cooler in front of radiator is the ATF cooler??
Seems mine has decided to start leaking from one of the pipe connections......AH:angry:
This cooler must be under low pressure as just normal pipe connectors.
Anyone any idea cost of cooler / or if repairable being a low pressure item??
Is it the rubber hose connection that is leaking as it may just be a case of cutting off the end and refitting with a new clamp.
If it is one of the metal pipes on the cooler a radiator repair specialist should be able to rebraze the joint.
New replacement is part number 32913-53020 priced at a mere £300.00 from Lexus!
All good....was the crappy pipe clip and a furred up pipe.
Cleaned up and fitted decent jubilee clip - no leak.
Arm looks like its went 10 rounds with a tiger - not a lot of space to work in.
Glad you mentioned "decent jubilee clip" I bought some cheapies recently, hopeless, never buy cheap ones, I certainly won't again!
and make sure stainless if possible.
