Sbs 2003 Install Problem
Zaphod
OOOPS! I should have placed this in Non-Car chat - sorry.
Clean install all new server build.
MSI 865PE Neo2 FIS2R M/B
512MB Kingston DDR400 RAM
P4 2.6
Radeon 7000 AGP
2 x 250GB Hitachi SATA HDD RAID mirror
Promise Fasttrack 378 RAID drivers installed (F6)
300W + 300W redundant PSU
Onboard Gigabit ethernet
Install runs o.k. till 60% through "Installing Drivers" on
SBS setup screen. Screen then goes black and all HDD
activity stops. No Keyboard or mouse actions. Monitor LED
is orange indicating nil o/p from video card.
A hard reset is required to restart the server. The
windows "resuming setup" screen appears and it restarts
the install process. It hangs at the same point a second
and sometimes a third time before it gets past
the "installing drivers" section and carrys on to do
the "registering components" section of the install.
I have also tried the installation - starting from scratch
using a single SATA drive with no additional drivers (i.e.
not using F6), and an also tried with a single 80GB IDE
drive with the same results. I swapped out the M/B (brand
new) with another one (same breed, also brand new) with no
change in the pattern.
I have little enough hair as it is and this is just
reducing coverage by even more. Fortunately it is the eval
version, but my decision on whether to go the whole hog
and recommend this as the next step in our companies
technology strategy is somewhat dented.
I have seen the notice pertaining to the Sharepoint
services prob and wonder if this may have some bearing on
this frustrating situation. Although I finally seem to get
the OS on, it does not fill me with confidence about the
stability of the installation when the pressure comes onto
it.
Any help on this would be greatly appreciated. :duh:
Be well.
Zaphod.
May be worth checking out this article:
http://support.microsoft.com/default.aspx?...kb;en-us;828267
It might be worth taking a look at the log file that it talks about - are there any other OS's on this box or can you install one temporarily just to get to the file (you may be able to use the recovery console if you have an XP cd) otherwise it might be worth putting a parallel install of XP or 2000 or something on there that can read an NTFS partition
OTher things you could try would be to reset the BIOS settings etc and maybe try disabling USB, firewire ports etc in the BIOS and then bring them back one at a time to see if you can identify the dodgy device.
Other thing to check is that you have the latest BIOS version installed on the Mobo.
Apart from that maybe dodgy RAM or CPU??
MS Server OS's do run much better on server specific hardware, I've not touched it on anything other than Compaq / HP server kit and never really had a problem like this....
