Power folding mirror kit wiring
matinzk
I got the driver's side door panel off and realised that everything is pretty much plug and play. Only thing that took a while was routing the cables from the door through the grommet into the cabin.
Swapping the mirror mechanism took around half hour. At the moment only the driver's side is done. Also the button that came with doesn't work for some reason. I am investigate this at the minute.
The mirror however closes when you double lock the car and opens when you unlock the car.
Any questions let me know.
  • 4 weeks later...
Hi everyone,
I have fitted these and they work great. The passenger side one however looks to close slightly more than the drivers side one. Is this normal on the CT? Are yours the same or they should close exactly the same?
  • 6 months later...
