Possible First Problem with LC500
malcolmw
My LC500 has suddenly started to do about 3mpg less than usual and is making the V8 growl at all revs instead of the exhaust valves opening at over about 4K. I think the valves are stuck open and the resulting lower back pressure is what is causing the mpg loss.
I am going to contact my dealer tomorrow for them to have a quick look. It's hardly a serious issue but something has changed at about 4700 miles up.
Has anyone else experienced this?
More true with hybrids than conventional ICEs, I think but this was like a switch being turned rather than a slow process as the weather cooled. Back in March my mpg was still pretty good in the cold.
Well, Lexus Hedge End did have a quick look but requested to have the car for a few days to diagnose the problem properly. It was due to go in on Tuesday but I will be contacting them tomorrow to cancel the appointment as the problem seems to have gone away. I thought the car was back to normal on Thursday but I wasn't certain that it just wasn't me getting used to the changed sound.
I took my partner out for a trip to Lymington today and she is also convinced that the low rev growl is gone and silence has returned when cruising. I also noticed that the exhaust "crackle" is back if you give it a boot in Sport mode and the sound now picks up at about 4000 rpm like it did before.
Now, I have realised that the changes to the car have coincided with a refuelling both times. Is this coincidence or causation? I filled up just before I noticed the noisier exhaust and refuelled again last Wednesday. Since this refill, my MPG has gone back to 25+. Could a fuel problem really have caused this or have the valves just become unstuck?
Where did you fill up? I know that Tesco had some contaminated fuel recently.
Fuel problem could have caused the issue yes.
