After I think you might need to use ‘Techstream’ to bleed all the air from the braking system especially if you have removed the ABS unit like you intend.
Welcome to the LOC.
I’ve never heard of an ABS block failing,  what are your symptoms and fault codes Valerijs?
There is normally a bleed nipple on the block.
